What is the atom density of aluminium at 600K?
  • Thread starter Thread starter alfredbester
The atom density of aluminum at 600K was calculated to be 2.24 x 10^28 m^-3 using the Debye model and sound velocity data. The calculated density, derived from the atom density and aluminum's atomic mass, resulted in 1000 kg m^-3, which is significantly lower than the true density of 2700 kg m^-3. The discrepancy raises questions about the assumptions made in the Debye model, particularly regarding the number of atoms vibrating at the characteristic frequency. It is suggested that the atom density may reflect only a portion of the atoms in the material, leading to the lower density value. Further exploration of the assumptions in the Debye model may be necessary to reconcile these differences.
alfredbester
Hi, I appear to have lost some mass/density.
Q: Calculate the atom density, n, of aluminium at 600k.
Data given (some of it not relevant to this part of the ? but i'll post it all).
The debye temperature T_D = 428 K . The velocity of sound at room temp, v = 5100m s^{-1}. The interatomic spacing a = 405pm, and its relative atomic mass is 27.
I found the atom density n to be:
n = (KT_D / \hbar v )^3.(1 / 6\pi^2)
I used {\omega_m}^3 = 6\pi^2 v^3 n, and the fact {\omega_m} = K T_D / \hbar to get my equations for n.
I assumed the atom density was the same at 600k as at room temperature (the way the question was worded I couldn't see any other method). Plugging the numbers in I found n = 2.24x10^{28} m^{-3}.
Then I'm asked to compare the density found with aluminiums true density of 2700 kg m^{-3} and explain any difference.
My density is just the atom density multiplied by the atomic mass (assuming the mass is just contained within the aluminium).
Therefore
/rho = n m(amu) = n = 2.24x10^{28} * (27 / 6.022x10^{26})) = 1000 kg m^{-3}.
There in lies my problem. I'd expect my approximations to overestimate the density if anything.
Is there anyway my density could be right? Maybe some assumption of the debye model I'm not aware of. I've got the formulas straight out the textbook I don't see how it could be wrong and it's the right order of magnitude.
Just had a thought is the atom density n, the number of molecules vibrating at {\omega_m} / volume. Guess that would explain why the density is significantly lower, since many atoms won't be vibrating at {\omega_m}.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
