Help solving log (natural number) equation
  • Thread starter Thread starter Muskox
    Log
To solve the equation 2lnX = 2 + ln(X-1), the first step involves raising both sides by e to eliminate the logarithm. This leads to the equation X^2/(X-1) = e^2. By rearranging, it simplifies to X^2 = e^2(X-1), resulting in the quadratic equation X^2 - e^2X + e^2 = 0. The next steps involve applying the quadratic formula to find the values of X. This method provides a clear path to the solution of the logarithmic equation.
Muskox
I am stuck on finding the solution to this problem.
2lnX = 2 + ln(X-1)
Please show all steps for the solution.
Thank you.
Try raising both sides by e. Use algebra to simplify.
- Warren
I get this far.
X^2/X-1 = e^2
X^2 = e^2(X-1)
x^2 = e^2 X - e^2
You now have a quadraic equation in x. Remember e2 is just a number.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
