What am I doing wrong in solving the heat equation in 2 dimensions?
JohanL
Im trying to solve the heat equation in 2dim on a plate.
0=<x=<L, 0=<y=<L. With homogenous dirichlet conditions on the boundary and the initial condition:
T(x,y)=T0sin(pi*x/L)sin(pi*y/L)
With separation of variables i get the solution
<br /> T(x,y,t)=\sum_{m=0}^\infty\sum_{n=0}^\infty B_{mn}*exp[\frac{-(m^2+n^2)\pi^2kt}{L^2}]*sin[\frac{m\pi x}{L}]*sin[\frac{m\pi y}{L}]<br />
m,n integers and k the constant from the heat equation.
Now the initial condition determine the constants B_mn
<br /> B_{mn} = \frac{4T_0}{L^2}*\int_{0}^{L}\int_{0}^{L} sin[\frac{\pi x}{L}]*sin[\frac{\pi y}{L}] sin[\frac{m\pi x}{L}]*sin[\frac{n\pi y}{L}] dx dy<br />
But an integral like
<br /> \int_{0}^{L}sin\frac{\pi x}{L}sin\frac{m\pi x}{L}dx<br />
is zero for m not equal to 1.
So m=1 and n=1...?
and with this i don't get a Fourier series as the solution...
What am i doing wrong ?
"Bmn= 0" is not an initial condition! Your initial condition is that
T(x,y,0)=\sum_{n=0}^\infty B_{mn}sin[\frac{m\pi x}{L}]*sin[\frac{m\pi y}{L}]= T_0sin(\frac{\pi x}{L})sin(\frac{pi y}{L})
Now, apply the Fourier integral to both sides of that.
I never said that Bmn= 0 is an initial condition, i said that the integral is zero for m NOT equal to one, because of the orthogonality of sin-functions.
Im not sure what you mean by applying the Fourier integral, i have only used that with Fourier transforms.
This is how i get the expression for Bmn:
I have the general solution
T(x,y,t)=\sum_{m=0}^\infty\sum_{n=0}^\infty B_{mn}*exp[\frac{-(m^2+n^2)\pi^2kt}{L^2}]*sin[\frac{m\pi x}{L}]*sin[\frac{n\pi y}{L}]
Then i expand the initial condition in the eigenfunctions
(sin[\frac{m\pi x}{L}]*sin[\frac{n\pi y}{L}])_{m,n=1}^{\infty}=\Psi<br />
The initial condition is
f(x,y)=T_0sin(\frac{\pi x}{L})sin(\frac{\pi y}{L})
T(x,y,0)=\sum_{n=0}^\infty\sum_{m=0}^\infty B_{mn}sin[\frac{m\pi x}{L}]*sin[\frac{m\pi y}{L}]= f(x,y)
I multiply with the eigenfunctions and integrate over the domin to get an expression for Bmn:
B_{mn}=\frac{(f,\Psi)}{(\Psi,\Psi)}
where the normalisation integral is
(\Psi,\Psi) = \int_{0}^{L}\int_{0}^{L}sin^2[\frac{m\pi x}{L}]*sin^2[\frac{n\pi y}{L}] dxdy=L^2/4
and
(f,\Psi) = T_0*\int_{0}^{L}\int_{0}^{L} sin[\frac{\pi x}{L}]*sin[\frac{\pi y}{L}]*sin[\frac{m\pi x}{L}]*sin[\frac{n\pi y}{L}]dxdy
this integral is
(f,\Psi) = T_0\int_{0}^{L}sin[\frac{\pi x}{L}]*sin[\frac{m\pi x}{L}]dx\int_{0}^{L} sin[\frac{\pi y}{L}]*sin[\frac{n\pi y}{L}]dy
but for m not equal to 1
\int_{0}^{L}sin[\frac{\pi x}{L}]*sin[\frac{m\pi x}{L}]dx=\frac{1}{2}\int_{0}^{L}cos[\frac{(1-m) \pi x}{L}]dx+\int_{0}^{L}cos[\frac{(1+m)\pi x}{L}]dx=\frac{Lm*sin(m\pi)}{\pi-m^2\pi}=0
and the same for the integral over y.
Therefor m and n has to be 1 and i don't get a series solution!
Im probably doing some silly misstakes, can you find them?
hmm, i was probably right from the beginning.
I got confused because i had never solved a problem before where this happens.
Is it like this? :
When you have a certain "frequency" as the initial condition you can't get a solution for later times as a superposition over other frequencies.
Thats why in this case only the terms with m=1,n=1 survived in the sum.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
