Rotational Center of Mass question
When an object is spun and released under gravity, it rotates around its center of mass (CoM) as it falls. If spun off-center, it will not drop straight down but will fall to one side while still rotating around its CoM. In a gravity-free environment, a rotating object spun off-center will not simply remain still or spin lopsided; it will move in the direction its CoM was traveling at the moment of release. This behavior applies regardless of whether the rotation is around one or multiple axes. Therefore, the object will always find its CoM when released, even without gravity.
Charlie Van Neste
On earth, under the influence of gravity, when an object is spun/rotated and then released, it will find its center of mass and rotate around that as it falls. So, if you spun a very straight uniform stick at its exact center of mass say 1 meter off the ground and then released it, it will drop straight down: continuing to spin at its center of mass as it falls. However, if you spun it off center and released it, it will always find its center of mass but will not drop straight down, instead it will fall to the left or right (depending on which way you are spinning it). Hopefully that wasn't explained too confusingly...
Anyway here’s the question. In an environment without gravity, will a rotating object that’s spun off center naturally find its center of mass when released? Or will it just sit still and spin lopsided - if you catch my meaning. I seem to think it will always find its center of mass when rotating whether in the presence of gravity or not. Anyone know the answer to this? Thanks!
Note that when I'm saying spin, or spun, I'm referring to rotation. I'm also restricting the rotation to just 1 axis - although I think the same answer will apply to multiple axes of rotation.
Your intuition is correct. The object will fly off in the direction its CoM was moving when it was released, and rotate around its CoM.
Excellent! Thank you very much for you help.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
