Circuit Building: Red Stop Light | North/East LED
  • Thread starter Thread starter Marth164
    Circuit
The discussion revolves around creating a red stop light circuit using LEDs for north and east directions, ensuring that when one side is green, the other is red. The layout involves using a 4017 decade counter, which will cycle through the LED states but may require adjustments for optimal functionality. Suggestions include connecting specific output pins to represent the traffic light states and questioning the necessity of certain resistors and diodes in the design. Concerns are raised about the schematic's clarity and the potential need for current drivers to support the LED outputs. Overall, the conversation emphasizes the importance of proper connections and component selection for effective circuit operation.
Marth164
hello I am trying to make a simple red stop light circuit and I am wondering if this layout would work (one set of leds is for north and other is for east) like i want when the norht side is green the east side is red and other way around and when north is yellow east is still read
Welcome to PF, Marth. I can't help you with your question because electronics is not my thing. I do, however, want to compliment you for what is probably the best circuit diagram that I've seen posted in these forums.
If you are using a 4017 decade counter, only one of the output pins will be on (therefore only one LED will be on at a time). To me, it looks like the design will cycle through every LED (staying at green 2 cycles longer).
I think the LEDs will cycle as follows (N=North, E=East, G=Green...)
NG - NG - NG - NY - NR - EG - EG - EG - EY - ER - Back to beginning
I'm also confused as to why you have the diodes in series with the green and yellow LED and not with red. Is there a reason you want them in there?
If I were to do it with the 4017 I would set MR to Q3 (maybe Q4 depending on the timing) to force the counter to go back to Q0. This would give you 4 states (Q0-Q3) corresponding to the 4 different states of the system:
NG ER; NY ER; NR EG; NR EY
With this you would connect the following:
Pin 3: Q0: NG and ER
Pin 2: Q1: NY and ER
Pin 4: Q2: NR and EG
Pin 7: Q3: NR and EY and Pin 15: MR
(I also don't think that 100k resistor or 6.8 nF cap are necessary)
Its been a little while so I invite people to examine my suggestions.
D Dean
Of course you still need a resistor before each LED and I don't think you need any diodes.
Also, I' may be wrong but I'm not sure that the 10k resistor between the 555 and 4017 is necessary.
Actually, it's a rather bad schematic, mainly because it only gives pin numbers for the devices, rather than pin names. You have to go to the device datasheets and look up what pin 5 does, for example, to even follow how it's connected.
- Warren
Well, I meant for neatness and clarity, and the colour doesn't hurt. I didn't realize that the pins need to be named.
edit: That's peculiar. I just clicked on it again (several times), and a bunch of it is missing now.
I looks like an attempt at diode logic.
This is the functional equivilent of a prom chip.
The truth table for the diode matrix needs some work.
The 6.8nf and 100k are for power on reset. Nice touch.
Don't know if a 4017 can drive that much current.
Check the spec. You may need to add current drivers to the outputs.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
