Protecting Your Laptop During Thunderstorms: Lightning & Ethernet Risks
  • Thread starter Thread starter Rach3
    Lightning
A laptop on battery power connected to an AC-powered router during a thunderstorm faces minimal risk from voltage spikes. Significant damage to the laptop's network interface card (NIC) is unlikely due to the multiple components that would need to fail simultaneously to allow a spike through the ethernet cable. Typically, a lightning strike would damage one component, creating an open circuit that limits further damage. The router's ethernet line drivers are designed to fail open quickly, preventing excessive current flow. Additionally, the laptop's NIC includes robust electrostatic discharge (ESD) protection, which would likely absorb any incoming voltage spikes effectively.
Rach3
Suppose I have a laptop on battery power, connected to a network router which is AC powered, during a thunderstorm. Will a voltage spike at the router cause any damage to my laptop NIC?
It certainly could, but it's not very likely, either.
A lot of devices would have to fail in some very specific ways (the wall transformer, the regulators on the router's circuit board, the drivers on the transceiver IC, etc.) to permit a large voltage spike onto the ethernet cable. The majority of the time, the lightning strike would essentially vaporize one of these components, creating an open circuit that would limit its damage. This could be called "failing open."
Futhermore, the actual ethernet line drivers in your router are on an integrated circuit. They connect to the outside world through very tiny gold bond wires, each smaller in diameter than a human hair. They cannot carry much current at all before vaporizing, so it's not very likely that a significant amount of charge could be pumped through the driver before it fails open.
On the other end, your laptop's NIC has an ethernet transciever with a lot of ESD protection built into it, including snap-backs or clamps and beefy diodes. They would probably happily absorb any voltage spike that comes through the ethernet cable, given that the transciever on the other end is rather self-limiting -- it would fail open before it could transmit much charge.
- Warren
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
