Why does Harry's vacation start early?
  • Thread starter Thread starter parker21
    Figure
Harry the painter's vacation starts early due to a critical mistake in securing his safety rope. Initially, the rope supports him without breaking because it is anchored in a way that distributes his weight, allowing it to handle more than its breaking point. However, when he ties the rope to a flagpole, it only has one point of support, leading to a direct load of 500 N, which exceeds the rope's breaking limit of 300 N. This results in the rope snapping and causing Harry to fall. The discussion highlights the importance of understanding static equilibrium and the forces at play in such scenarios.
parker21
Harry the painter swings year after year from his bosun's chair. His weight is 500 N and the rope, unknown to him, has a breaking point of 300 N. Why doesn't the rope break when he is supported as shown to the left below? One day Harry is painting near a flagpole, and, for a change, he ties the free end of the rope to the flagpole instead of to his chair as shown to the right. Why did Harry end up taking his vacation early?
. How does the direction of a friction force compare with the velocity of a sliding object?
I don't know where your diagram is but I suspect that in the first case the rope is hooked over something and connects to the chair in two places (in which case, each holding so it can support 600 N) and in the second case he just has one piece of rope which breaks when he puts 500 N force on it.
AM
AM you are insightful. This is question 34 from chapter 4 of Paul Hewitt's Conceptual Physics text. And your assumption is correct.
Parker21: there is no friction in this problem (at least it is not significant) and you do not compare forces with velocities, and anyway nothing is sliding since this is a "static equilibrium" problem. Read your textbook section 4.7 .
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
