Smallest, Cheapest 110VAC -> 20VDC, 10AMP Power Supply
The discussion revolves around the challenge of finding a compact and affordable power supply that converts 110VAC to 20VDC at 10AMP, ideally under $100 and within dimensions of 5" x 3" x 2". There is a noted barrier in the market at around 120 Watts due to UL certification requirements, which complicates the design for higher power outputs. The user is considering two design options, with the primary factor being cost, as exceeding the budget would necessitate a more complex and less desirable solution. Additionally, it is emphasized that patent applications do not require precise engineering details, allowing for flexibility in the design of supporting components. The conversation highlights the importance of understanding patent requirements and market limitations in product development.
Magic-Rat
All,
Well, I have this idea for a patent ... but ... it requires a power supply ... and I can't find one that meets my needs.
I need to come up with the smallest, cheapest 110VAC -> 20VDC, 10AMP (or close to that) power converter (about 190 - 200 Watts), constant voltage.
Small means about 5" X 3" X 2".
Ideally, I would find some commercially available power supply for less than $100 a copy and adapt it ... but, no such luck. I can't find one that size at any price.
There seems to be a barrier at about 120 Watts. This is due (I think) to the U/L certification requirement for 30 cfm air flow (fans) to get any more power than about 120 watts. So, things above 120Watts get a lot bigger (about twice as big in terms of form factor).
But, maybe ... hopefully ... I'm wrong about that.
I have two design ideas and the primary factor that differentiates the two is cost. A small $100 or less unit makes my desired plan the best option. If price is above $100 then I must go to the second option (which allows a bigger power supply but requires lots more cables and other manufucturing ... it's not as good a design ... but it will work).
I dunno.
So ... anybody think of anything??
You must realize that if you are using this for a patent application, then whoever answers you is entitled to a share of the profits. (And it won't be me, because I don't know this kind of stuff.)
Patents are not concerned with price. Also, if this is only a suppoting component (aka. not a critical part of your novel idea) just write your requirements for this secondary device and don't worry about the precise implementation. Your patent only needs to describe your idea. It is not the same as an engineering document/plan. i.e. you don't take a patent to the factory. Took me a long time to figure that out too.
Note This:
http://www.gravitywarpdrive.com/Adobe_pdf_Files/USP_3626606_Orig_Doc.pdf
Not 100% sure this is real but the uspo does know of it. Anyway, hopefully you get the point.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
