How Does Heat Affect the Bullet-Wood Problem?
  • Thread starter Thread starter infraray
    Heat Wood
infraray
How is the bullet-wood problem different in setup if:
a)the bullet stops in the wood
b)if the bullet goes through the wood?
Is it that (a) would be an inelastic and (b) would use conservation of momentum?
Other question is how can energy loss by heat be calculated by this type of problem?
Both are inelastic and both conserve momentum. Heat would be calculated by finding the mechanical energy lost in the process.
Yes, in both cases kinetic energy is not conserved. When calculating the heat energy which is equivalent to loss in KE, we have to assume that no energy is converted to producing sound.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
