Compute Aphelion from Eccentricity & Perihelion
  • Thread starter Thread starter Logarythmic
    Comet Orbit
Logarythmic
If I have the eccentricity and the perihelion of an orbit given, how can I compute the aphelion?
You need to think of what angles correspond the the perihelion and aphelion. Then use the relation between r, e, theta and l to get the aphelion.
Can I not just use the relation for an ellipse:
e = \frac{d}{a}
where d is the distance from the focal point to the center and a is the semi major axis?
Well yes if you know a and d. You'd get the same result. You might need J as well though.
I just used the radial equation
r_a = \frac{a(1 - e^2)}{1 + e \cos \pi} = a(1+e)
This leads to
r_a = \frac{r_p(1+e)}{1-e}
where I have used that
a = \frac{r_a + r_p}{2}
But for r_p = 0,2301 AU I get r_a = 2988 AU and this is wrong. I should get r_a =4699 AU. Am I too tired or what is this?
I have that e = 0,999846
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
