Homework: Braking Force Magnitude
  • Thread starter Thread starter XPX1
    Brake Homework
The discussion revolves around calculating the average braking force and distance traveled while braking for a car slowing from 16.0 m/s to 9.50 m/s over 1.15 seconds. Participants initially struggle with applying the correct equations to find acceleration and force, eventually determining that the average force exerted during braking is -5.763 kN, with the negative sign indicating direction. The correct magnitude of the force, disregarding direction, is 5.763 kN. For the distance traveled while braking, the calculation yields approximately 14.663 meters. The importance of unit conversion and understanding the significance of negative values in physics is emphasized throughout the discussion.
XPX1
Driving home from school one day you spot a ball rolling out into the street (Figure 5-18). You brake for 1.15 s, slowing your 1020 kg car from 16.0 m/s to 9.50 m/s.
a) What was the average force exerted on your car during braking?
Magnitude
_____ kN
(b) How far did you travel while braking?
xf=xi+.5(vi+vf)t
vf^2=vi^2+2a(xf-xi)
I have been unable to figure out this problem!
From the information gathered, I know the following
vi=16.0
vf=9.5
t=1.15
now I do not know where to go from here, I've tried using the above formulas to find the acceleration so I can plug it into the Fnet=MA equation, but still I am kind of lost. How the heck do I find the average force exerted on the car while brakeing
Magnitude
_____ kN
xf=xi+.5(vi+vf)t
vf^2=vi^2+2a(xf-xi)
vi=16.0
vf=9.5
t=1.15
Use your relevant equations and solve for Xf and a, setting xi = 0. Then yes use f=ma to solve for the average force during braking.
im still kind of confused, I think the equations I need to use for acceleration are vf=vi+axt, but I still got the question wrong, even for part b where it asks me how far it went! Somebody please halp!
vf=vi+axt then
9.5=16+1.15a
-6.5=1.15a
a=-5.65 am I not correct?
vf=vi+axt then
9.5=16+1.15a
-6.5=1.15a
Your acceleration looks OK. How do you find the force? What distance did you get for b? Your equations are OK.
well b should be -5.65(1.15) which = -6.4975 but that is not correct for b.
and if I was to do the Fnet I would assume that Fnet=MA
Fnet= 1020(-5.65)
right?
Fnet= 1020(-5.65)
right?
The force is correct once you get the units included. Multiply it out. The distance is not correct. Keeping track of units will help you know when things are not right. What you calculated is acceleration times time, which has units of velocity and is in fact the change in velocity. Go back to either of your two oringinal equations and compute xf - xi. That is the distance.
but how do I find xf or xi if I know xi = 0 and xf = ?
I plugged it into the position versus time graph and got xf=14.663
xf=xi+vixt+.5at^2
xf=0+16(1.15)+.5(-5.65)(1.15)^2
Woohoo I got b. correct! But now for a. Fnet=MA then Fnet= 1020(-5.65)
Fnet = -5763
Then the average force exerted on the car while breaking is -5763 kN?
kN I am guessing is kiloNewtons?
Fnet = -5763
You are not keeping track of your units. 1Kg*m/s^2 = 1 Newton
so how do I convert -5763 to kiloNewtons?
Infact what is -5763? If the mass is kilograms and the acceleration was in.. meters?
Then.. -5763 would be kilograms right? 1 kilogram = 9.8 Newtons? and 1000 Newtons = 1 kiloNewton? so -5763 would be -57630?
You have to study up on the units. The acceleration is in meters/second^2. Velocity is in meters/second. Distance is in meters. And 1 Newton is shorthand for 1Kg*m/second^2. and 1000N = 1kN .
F=ma
F=
1050Kg(-5.65m/s^2) = -5763Kg*m/s^2 = -5763N
-5763N(1kN/1000N) = - 5.763kN
As an aside, you should note that the fprmula for weight, which is unrelated to this problem, is W=mg, so 1Kg weighs (1)9.8 Kg(m)/s^2 = 9.8 Newtons
-5.763 kN was not correct, I still don't understand!
Maybe the car was moving to the left. Try using +5.763kN.
EDIT: Oh, now i see the problem asked for the magnitude of the force, not the direction. The minus sign means that the force is opposite the direction of the car's motion. The magnitude of the force is 5.763kN.
