Finding Moment of Inertia: 2 Questions Answered
The discussion focuses on finding the moment of inertia for two shapes: a rectangular sheet and a thin uniform disk. For the rectangular sheet, the moment of inertia is calculated using the integral I = (integral over A) M/A dA, with the density σ defined as M/A. Participants suggest using the formula I = σ ∫ r² dA, where r² is expressed as x² + y², and emphasize determining the correct limits of integration based on the rectangle's dimensions. For the thin disk, the moment of inertia is confirmed as I = Ma²/2 when integrating over the disk's area. Overall, the conversation provides guidance on applying integral calculus to derive the moments of inertia for these shapes.
jlmac2001
I'm don't really know how to find the momemt of inertia. I have two questions that I'm stuck on.
Two questions:
1. Find the moment of inertia of a sheet f mass M and uniform density which is in the shape of a rectangle of sides a and b, for rotations about an axis passing through its center and perpendicular to the sheet.
answer:Will I start with this I= (integral over A)M/A dA? How would I find the limits of integration and integrate this?
2. Find the moment of inertia of a thin uniform disk of mass M and radius a for rotations about an axis through a diameter of the disk.
answer: Will th answer be I=2M/a^2 (a^4/4)=Ma^2/2?
Two questions:
Start with:
\int r^2 dm = \int r^2 \sigma dA = \sigma \int r^2 dA
Where \sigma is the constant density \frac{M}{A}
hope that helps
dnn't understand
could someone explain itto me?
Originally posted by Norman
Start with:
hope that helps
\sigma \int r^2 dA =\sigma \int (x^2+y^2)dxdy
this is ok since if you draw the rectangle out, r is measured from the center of the plane and therefore r^2=x^2+y^2. Since the center of the plane is the axis of rotation... you should be able to figure out the limits of integration for x and y.
Cheers.
