Initial Velocity and Projectiles
To determine the initial velocity of an object shot vertically, kinematics equations can be used to predict height and distance when given a launch angle. The maximum height is calculated using the formula v² = 2gh, where 'v' is the launch speed. When launched at an angle θ, the vertical component of the velocity is v*sinθ, and the height can be found using h' = v²sin²θ/2g. The relationship between heights for different launch angles is expressed as h'/h = sin²θ, indicating that changing the launch angle affects the vertical height. Understanding these equations clarifies how to analyze projectile motion effectively.
fyzikschik
I have a general question. If you were to determine the intial velocity of an object shot vertically into the air, how could you use kinematics equations to predict the height and distance the object would reach if you were then later given a launch angle? Does this mean that the initial velocity is just multiplied by components? I'm really confused. Projectile motion is clearly involved in the second part.. I could measure the time and height when I'm finding the initial velocity, but then what am I using to find height and range at a given angle? Please help without subtlety! Pleease!
If an object is launched vertically, its maximum height is determined by the launch speed (neglecting any air resistance). Given a height you can calculate the launch speed from
v² = 2gh
If the object is launhed with the same spped, but at an angle θ relative to the horizontal then yes, you need to find the components. The vertical component would be v*sinθ and the height would be found by solving
v²sin²θ = 2gh'
If you divide these two equations you get
h'/h = sin²θ
which is valid only if you are comparing projectiles launced at the same speed but with one vertical and the other at angle θ.
Would changing the launch angle change the vertical height?
See the above equation: v²sin²θ = 2gh', which gives h'= v²sin²θ/2g
Given that v is the same in all cases, and g is the gravitationla field strength constant, can you now answer your question?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
