Help with an h bridge controller
  • Thread starter Thread starter rockstar
    Bridge Controller
The discussion focuses on using p-type MOSFETs for an R/C car's H-bridge controller, specifically questioning the feasibility of avoiding voltage pump circuits while still enabling PWM torque control. The user has replaced n-type MOSFETs with p-types due to lower internal resistance, which is crucial for handling high current in a large 1:4 scale R/C car. There is a debate about the performance of n-channel versus p-channel MOSFETs, with some participants suggesting that n-channel devices may offer better performance. The conversation includes requests for datasheets of the specific MOSFETs being used to assess their suitability. Overall, the thread emphasizes the challenges of optimizing MOSFET selection for efficient control in high-current applications.
rockstar
i'm using p type mosfets for an r/c cars h bridge controller (the two n types have been replaced with p types because of their lower internal resistance) and was wondering if there is a way to do it without voltage pump circuits that stills alllows a P.W.M. torque controller.
So you're using p-type mosfets for the low-side switches as well?
EDIT -- I would have thought the n-fets would have better performance. What are the devices?
large 1:4 scale r/c car and use a LOT of current the difference in the internal resistance was becoming a problem in heating, and srry it was n types just i was typeing without thinking
Okay, so you want to use n-channel power MOSFETs for the high-side switches instead of p-channel. Hmmm, got to think about that one. Do you have a pointer to the n-channel device datasheets? And maybe one to the p-channel FETs that you are trying to replace.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
