dpsguy said:
Thanks Monique!
BTW, shouldn't that be RNA polymerase in the first line?
You are absolutely right.
Just a little problem: if transcription factors(TFs) are protiens, then there must be a regulatory mechanism for them too. Does that mean that there are TFs that regulate TFs?
Yes, but you wouldn't call them transcription factors, but regulatory proteins. A very well-known and much-used example for gene-regulation is the LacZ gene (part of the lac operon). It is often cloned into a vector and used as a reporter gene.
The way it works is that the lac repressor protein (lacI) binds to the lac operon and thereby prevents transcription. When IPTG is added, the lac operon is de-repressed, due to the binding of IPTG to lacI, preventing it from binding the lac operon. Now the gene can be transcribed and translated into beta-galactosidase, a protein with enzymatic activity. The substrate for the enzyme is X-gal, which when cleaved leaves a water-insoluble blue product, which can be used as a reporter.
A way to envision the use of this LacZ protein is for instance to monitor whether you have cloned (inserted) a gene into a vector (a circular piece of DNA from viral origin). When the system is intact, you will get blue bacterial colonies (these are the 'test tubes' in which you perform the reaction), when the LacZ gene is disrupted by an inserted protein, you get white bacterial colonies.
If so, does a feedback mechanism operate, like in operons? And how does the external environment of the cell come into the picture?
The link very helpfully given by Iansmith talks about external stimuli affecting cellular receptors which "can activate many downstream effector proteins". Then does this process bypass nuclear transcription? If not, what role do TFs have to play in this process?
There are many different pathways known that play a central role in signal transduction from the outside to the inside of the cell. Everything is highly regulated and there are often feedback mechanisms.
A well-known signal transduction pathway is the MAPK pathway, which is a kinase cascade where kinases phosphorylate kinases, which in turn will phosphorylate kinases. In this way the signal is greatly enhanced.
http://www.biocarta.com/pathfiles/h_mapkPathway.asp
The pathway in outline works like this: the epidermal growth factor receptor (EGFR) binds and is activated by the extracellular epidermal growth factor (EGF), by forming a dimer. The receptor-dimer can then cross-phosphorylate the tyrosines on its cytoplasmic tail.
Docking proteins such as GRB2, which contain an SH2 domain, can then bind to the phosphotyrosines. Then a guanine nucleotide exchange factor (GEF) binds to the SH3 domain of GRB2 and becomes active.
The GEF exchanges the GDP for a GTP on Ras, thereby activating it, which can continue to activate the protein kinase Raf. This sets off a whole set of kinases, which in the end go into the nucleus and signal to transcription factors (on the bottom in the diagram: Elk-1 c-FOS c-JUN ATF-2 SP-1 STAT-1 etc).
As seen in the LacZ example, some proteins will promote transcription, others will repress it. There is a whole other mechanism for gene repression/activation, which is based on histone-tail modifications. This is a very complex subject by itself.
