Calculating Gravitational Potential Energy: A to B
Gravitational potential at point A on Earth's surface is calculated using the formula U = -GM/r, resulting in approximately -6.26 x 10^29 J/kg. For point B, located 1000 km above A, the gravitational potential is about -5.41 x 10^29 J/kg. The energy required for a 10 kg object to reach point B from A is calculated to be approximately -5.41 x 10^30 J. The distinction between gravitational potential and gravitational potential energy is emphasized, with potential being energy per unit mass. The calculations provided are verified as correct based on the formulas discussed.
natural
Forces & Fields
(a) calculate the gravatational potential pf a point A on the surface of the Earth
(b) what is the gravatational potential of a point B, 1000km above A?
(c) How much energy is expended if an object of mass 10kg were to just reach point B from A?
I know the eq. for gravatational potential energy is U=-GMm/r ...but what do i use as my 2nd mass ? :confused: please help I am really lost :frown:
There is a difference between gravitational potential and gravitational potential energy.
Gravitational potential is the potential energy per unit mass of an object due to its position in a gravitational field. The gravitational potential due to a point mass:
Eg = -GM/r, where M is the mass of the object responsible for the gravitational field, whereas
gravitational potential energy is given by
mEg = -GMm/r
Please refer to this page - http://hyperphysics.phy-astr.gsu.edu/hbase/gpot.html
and the following plates including - http://hyperphysics.phy-astr.gsu.edu/hbase/gpot.html#gpi .
Are my calculations correct? just want to make sure>
a) -6.67*10^11 * 5.98*10^24/6.37*10^6 = -6.26*10^29
b)-6.67*10^11 * 5.98*10^24/ 6.37*10^6+1000*10^3 = -5.41*10^29
C)-6.67*10^11*5.98*10^24*10/6.37*10^6+1000*10^3 = -5.41*10^30
