Describe a locus Algebraically
  • Thread starter Thread starter jvercetti
The discussion focuses on describing the locus of points equidistant from the points (0,0) and (-6,-6) algebraically and geometrically. Participants clarify that the locus is the perpendicular bisector of the line segment connecting these points. The algebraic description requires finding the equation of this bisector, including determining the midpoint and slope of the line segment. There was confusion regarding the points used in the example, but it was resolved that the correct locus relates to the original points stated. Ultimately, the locus is confirmed to be the perpendicular bisector of the segment connecting the two specified points.
jvercetti
Describe the locus algebraically. Then graph the locus and describe the locus geometrically. Prove that the locus is the perpendicular bisector of the line joining the two points.
Locus of points equidistant from (0,0) and (-6, -6)
None that I can think of
Here's what I have done so far:
Locus of points equidistant from (-3,0) and (5,0)
Geometric description: P(x,y) where PA= PB where A = (-3,0) and B is always isosceles.
The locus is the perpendicular bisector of line AB. This occurs because the locus crosses line AB at its midpoint.
Algebraic description: Confused Here :shy:
Graph:
Thx in advance
Graphically - I cannot see the locus.
Geometrically - B is isoceles? what is?
You have not yet shown the locus is a straight line, or that it is perpendicular to AB, in fact you have shown it at all.
Algebraically - what is the equation of the locus
?? In the problem statement you say "Locus of points equidistant from (0,0) and (-6, -6)" but in attempt at a solution you say "Locus of points equidistant from (-3,0) and (5,0)". Which is it?
In either case, you are correct that, geometrically, the locus is the perpendicular bisector of the line segment having those endpoints.
The "algebraic description" means the equation of that line. What are the coordinates of the midpoint of the given line segement? What is the slope of the line through the given points? What is the slope of the line perpendicular to that?
Finally, your graph shows (-3, 0) and (5,0) (but not (0,0) and (-6, -6)) and shows one example of a point on the locus but does not show the locus which is what you are asked to graph.
"The locus is the perpendicular bisector of line AB"
Actually, that should be "the locus is the perpendicular bisector of line segment AB." So, you just need the equation of the perpendicular bisector of that segment.
Ok sorry.. I found the mistake I was making with the question.. Sorry about typing the question wrong.. I mixed two questions up.. Anyways the question I had, I found the answer to.. Sorry for the trouble
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
