What is the solution for the equation |x + a| = |x - b|, given that x=2?
  • Thread starter Thread starter unique_pavadrin
    Function
The equation |x + a| = |x - b| has a unique solution at x=2, leading to the conclusion that a and b must satisfy the condition 4 + a = b. The initial approach to solving the equation involved equating the expressions directly, but this method was deemed incorrect as it led to a contradiction. A correct interpretation suggests that for the equation to have one solution, the values of a and b must be related such that a = -b is not applicable since x is fixed at 2. The discussion highlights confusion over the proper steps to derive the values of a and b, indicating a need for further clarification on the problem.
unique_pavadrin
The equation \left| {x + a} \right| = \left| {x - b} \right| has exactly one solution; at x=2. Find the value(s) of a and b
2. The attempt at a solution
Here is the way in which I have approached the situation:
<br /> \begin{array}{l}<br /> \left| {x + a} \right| = \left| {x - b} \right| \\ <br /> x + a = x + b \\ <br /> \end{array}<br />
this solution is not possible as the x's on either side of the equation cancel each other out, and a is not equal to b, so;
<br /> \begin{array}{l}<br /> x + a = - x + b \\ <br /> 2x + a = b \\ <br /> 4 + a = b \\ <br /> a = k \\ <br /> a = k + 4 \\ <br /> \end{array}<br />
However I'm not sure on my my final answer, as I have not evaluated the values for a or b, as i have left them in the term of k. However what I have interpreted from the question, I have not been given enough information. Thank you to those who reply, and correct me if anything I have stated is wrong
unique_pavadrin
unique_pavadrin
Not sure how you got this step:
If you are taking both to be positive, it should be x + a = x - b
Then you can kill the x's. so a=-b.
thanks for the reply theperthvan
ive used those steps as a simply does not equal -b as the x can be anywhere on the number line. by stating that a=-b, x is a fixed point at zero, which is incorrect as z is given the value of 2
or is that completely wrong?
thanks
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
