Eigenvalues and eigenfunctions of the lowering operator
Ed Quanta
Consider lowering and rising operators that we encountered in the harmonic oscillator problem.
1. Find the eigenvalues and eigenfunctions of the lowering operator.
2. Does the rising operator have normalizable eigenfunctions?
a-= 1/sqrt(2hmw) (ip + mwx)
a+ = 1/sqrt(2hmw) (ip - mwx)
a-Ψ(x) = yΨ(x) where y is the eigenvalue
So I applied a-, the lowering operator to Ψ(x) and eventually ended up with the differential equation
dΨ(x)/dx + (mwx/h - sqrt (2hmw)y/h)Ψ(x)=0
I believe I solved this differential equation correctly using separation of variables and ended up with
Ψ(x)= A exp (-(mwx^2)/h + sqrt(2hmw)(y)x/h)
What do I do now? How do I find eigenvalue y? I know that a-Ψn(x)= sqrt(n)Ψn-1(x)?
Am I supposed to be able to come up with this result? If so, how? Thanks
a-Ψn(x)= sqrt(n)Ψn-1(x) in this example Ψ is not an eigenfunction of a-, this have no use here as far I can think of..
I'm thinking of applying a+ to the eigenfunction of a-, and see what it should give you..
You're looking for the wavefunctions of the coherent states for the harm. osc. See the treatment in Galindo and Pascual, vol. 1. It turns out that the spectrum of the lowering ladder operator is the entire complex plane.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
