How Long Does It Take to Empty a Tube Using Bernoulli's Equation?
  • Thread starter Thread starter domjoly1985
The discussion revolves around calculating the time it takes for a vertical tube filled with an inviscid, incompressible fluid to empty under gravity, using Bernoulli's equation. The user has successfully determined the speed of the liquid exiting the tube but is unsure how to calculate the emptying time. It is suggested that knowing the volume flow rate, derived from the speed of the liquid and the cross-sectional area of the outlet, allows for the calculation of emptying time. The formula proposed is emptying time equals total liquid volume divided by the volume flow rate. The conversation emphasizes the importance of understanding flow rates to solve the problem effectively.
domjoly1985
Hi, I have a problem involving involving Bernoulli's equation and the emptying of a tube of liquid over time, I will outline the problem and then the question...
There is a vertical tube, which narrows into smaller tube part of the way down, it is filled with an inviscid, incompressible and irrotational fluid. The bottom/outlet of the tube is at z=0, where the cross-sectional area is represented by A0 and the fluid's speed by q1. The top of the tube is at z=1, the top level of the liquid is at h(t), where t is time, the cross-sectional area of the liquid level is A1 and the speed it is falling at is q0. The pressure is the same at both ends of the tube.
I need to find out how long it takes for the tube to empty under gravity, using Bernoulli's equation, and assuming the flow is approximately steady.
Any help would be appreciated, if any more information is required I will reply asap. Thanks
Present your ideas/efforts.
Ive been able to get the speed of the liquid coming out of the bottom of the tube, but I have no idea where to start concerning it's emptying time.
If you have determined the speed of the liquid when it comes out of the tube and you know the cross sectional area of the outlet you can determine the volume flowrate out of the tube (q1*A0). Then you know how much volume of liquid exits the tube per second and you can use this information to determine the emptying time.
I realize that but to do it.
If the total liquid volume is V the emptying time is V/Q where Q is the volume flow rate out of the tube.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
