What kind of equation is this?
  • Thread starter Thread starter light_bulb
The equation 5t^2 - 100t = 480 is identified as a quadratic equation that requires solving for t. The correct approach involves rearranging the equation to 5t^2 - 100t - 480 = 0 and applying the quadratic formula. After correcting arithmetic errors, the solutions are found to be -4 and 24. The discussion highlights the importance of correctly changing the sign when rearranging equations. Overall, the participants emphasize the need for accuracy in calculations and understanding of quadratic equations.
light_bulb
5t^2 - 100t = 480
solve for t, book has it as one of the practice problems but doesn't show how to work it out.
It's a quadratic equation.
can you show me how to solve this? I'm getting stuck.
What have you tried to do already? Have you tried factoring it, or tried applying the quadratic formula?
yea i get {-2,18}. it doesn't look right?
heres what I'm doing:
5t^2 - 100t = 480
so
t^2 -20 + 96 = 0
then
[± 20 sqrt{400 - 4(1)(96)}] / 2(1) = t
Your last equation is correct, however you have made an arithmetic error-- it does not give the solutions -2 and 18.
light_bulb said:
[sqrt{400 - 4(1)(96)}] ± 20 / 2(1) = t
The order in the numerator is not quite right it should be
[20 ± sqrt{400 - 4(1)(96)}]/2(1) = t
your both right, {-8,12} but that still doesn't seem right?
Well you forgot to add change 480 to -480 since you flipped sides.
So...5t^2-100t-480=0 now the solutions are -4 and 24 and when you put them in the equation you get the correct solution.
\frac { 20 \pm \sqrt { (-20)^2-4 \cdot 1 \cdot (-96) } } {2 \cdot 1}
\frac { 20 \pm 28 } {2}
-4 works :)now if only the book would have mentioned that i needed to change the sign :/
one more time to make sure i got it right.
5t^2 - 100t = 480
so
t^2 -20 - 96 = 0
then
[± 20 sqrt{400 - 4(1)(-96)}] / 2(1) = t
now the calc buttons 4*-96 = 384
400-(-384) = 784
sqrt786 = 28
20-28 = -8
-8/2 = -4
thanks to all that helped!
The book shouldn't need to mention you change the sign, you should know how subtraction works by the time you deal with quadratic equations
Keep in mind that it's 20±28, so you have a second solution also
thanks:rolleyes:
