Heres a tough one i had on my final im dying to find out how to do it
  • Thread starter Thread starter xxacefirexx
    Final
The problem involves a mass rotating on a horizontal surface with air friction affecting its motion. The air friction is expressed as 0.2v, and the mass is 3 kg with an initial velocity of 10 m/s. To find the centripetal acceleration after 5 seconds, one must integrate the air friction over time, leading to a differential equation based on Newton's second law. The correct approach involves solving the first-order differential equation derived from the air resistance, considering the boundary conditions. Understanding this integration process is crucial for determining the centripetal acceleration accurately.
xxacefirexx
I don't remember the question verbatim, but here is all the info
There is a mass attached to a rope which is attached to a pole. It is set to rotate on a horizontal surface (basic circular motion scenario). There is no kinetic friction along the table, but there is air friction.
The magnitude of air friction is related to velocity with the equation .2v.
m=3 kg
r=2 m
v(initial)=10 m/s
What is the centripetal acceleration after 5 s.
F=ma=m(v^2/r)
i know you got to integrate the air friction function over the 5 s interval, but i can't express it in terms of t.
I am completely lost, please help. I know I got it wrong, but i really want to know how to do it.
Thanks!
m=3 kg
r=2 m
v(initial)=10 m/s
F=ma=m(v^2/r)
Thanks!
F=mv^2/r is the correct centripetal force formula for the tension in the rope, but the problem is asking for the centripetal acceleration only. You need first, however, to use Newton's 2nd law in the tangential direction, where the tangential acceleration is not constant. Thus,
use F=m(dv/dt), where F is the given air resistance force (presumably in force units of Newtons). You get a first order differential equation you must solve of the form -kv = mdv/dt. Solve for v and don't forget the boundary condition. Is this where you are stuck?
