How do I use partial fraction decomposition to integrate rational functions?
  • Thread starter Thread starter majdeee
majdeee
I tried this for the first one but :confused:
for the 1st question, let b=x, for the sake of tradition.
find d/dx (e^x-x^e)
find d/dx (e^x-x^e)=0 on the interval [0, infinity)
prove that the zero was a minium, substitute the x it into y= e^x-x^e
if the result is y=0, you have proved it
thinking about the second question and the third question.
To find all the zeroes of that derivative, you probably essentially need to do the original problem anyway
nope, graph it and see
1) For the first problem, look at the function f(x)=log(x)/x when x>=1.
You can easily prove that it has a maximum at e. But then,
log(e)/e>=log(b)/b
whenever b>=1. This says b>=e*log(b). If you exponentiate this, you find
e^b>=b^e
2) For the second problem, look at the function f(x)=x^x. You can easily how that this has a minimum at 1/e. However, the limit as x goes to zero of x^x is 1. Furthermore, 1^1 is also 1. Thus x^x decreases between 0 and 1/e and increases between 1/e and 1. So if you have a number, say a, between 0 and 1/e, there must be a number between 1/e and 1, say b such that a^a=b^b.
HTH.
--PatF
Thread moved to Homework Help forums.
this is the answer for the first 1
we need to prove e^b>=b^e
since ln(x) (natural lorarithm of x is continuous and monotonic increasing function we can take the natural logarithm of both sides of the inequality without disrupting it
so we may prove ln(e^b)>=ln(b^e)
by simplification
ln(e^b)=b*ln(e)=b*1=b
ln(b^e)=e*ln(b)
so we only have to prove that b>=e*ln(b)
it is readiely seen true for b=1 and b=e
(for b=e) we have equality
let's look at the two sides of the inequality as two functions of b
f1(b)=b
f2(b)=e*ln(b)
the derivatives of the functions are
df1(b)/db=1
df2(b)/db=e/b
for b>e df1(b)/db=1 and df2(b)/db=e/b<1
so that from value of b>e f1 increases faster than f2 and since they both start at the same value at b=e the inequality holds for b>e
for 1<b<e we have df2(b)/db=e/b>1 since b<e examining the regression of b from e to 1 it is regressing at a rate that is larger than 1 after starting from equal value of e it goes down faster than b therefore we have proven
does anybody know how to solve the third one??
For the third one, I would beging with:
P(x) = Ax^2 + Bx + C ; A,B,C are rational coefficients.
Then I would a partial fraction decomposition:
R(x) = \dfrac{Ax^{2} + Bx + C}{x^{3} (x-1)} = \dfrac{a_{0} ^{(1)}}{x^{3}} + \dfrac{a_{0} ^{(2)}}{x^{2}} + \dfrac{a_{0} ^{(3)}}{x} + \dfrac{a_{1} ^{(1)}}{x-1}
To find out the coefficients a_{1} ^{(1)}...
; you just write
R(x) = \dfrac{P(x)}{x^{3} (x-1)}
then you get a nice linear system of equations.
After this, do the integration (remember the constant of integration), then see what values of a_{1} ^{(1)} , and hence also values of A,B and C, that gives you a rational function.
