Calculating Fraction of Alcohol in Water-Alcohol Mixtures
The discussion focuses on calculating the fraction of alcohol in a mixture of water and alcohol. Participants clarify the difference between the ratio of alcohol to water (1:3) and the ratio of alcohol to the total solution (1:4). The confusion arises from how these ratios apply when determining the mass of alcohol in the original 8-gram solution. A simple example is provided to illustrate that the total mass of the solution is the sum of the masses of alcohol and water. Understanding these ratios is essential for accurately calculating the alcohol fraction in the new solution.
lLovePhysics
In an 8-gram solution of water and alcohol, the ratio by mass of water to alcohol is 3 to 1. If 12 grams of a solution consisting of 2 grams water for each gram of alcohol is added to the 8-gram solution, what fraction by mass of the new solution is alcohol?
-- I know that the first thing you should do is try to find the mass of alcohol in both the 8-gram and the 12-gram solution. However, to find the amount of alcohol in the 8-gram solution why would you multiply it by 1/4 and not 1/3? Its just confusing how the ratios can be written like 1:3 and then 1/4?
Mathematics news on Phys.org
The mass of the alcohol to water is 1:3, but the mass of the alcohol to the original 8 grammes solution is 1:4, hence multiply by 1/(3+1), hope this clears up the confusion.
Lol, I still don't get it. I know that for every 1 gram of alcohol there are 3 grams of water. I can solve it by doing it that way. But I can't seem to get why it changes when you find the amount of alcohol in the 8-gram solution. Mabye I'm dumb or something. I just suck at ratios.
Do you understand the difference between
"The ratio of alchohol to water is 1:3" and
"The ratio of alchohol to solution is 1:4"?
Well kind of. Solution would be the water + alcohol right? So you just add the msas of alcohol and the mass of water to get 4. Am I doing it correct?
Yes. Why don't you imagine a really simple example. Say you added one gram of alcohol to 3 grams of water. You now have a total of 4 grams solution of which one gram is alcohol. It's not exactly rocket science as they say. :)
I see! Thanks! :smile:
