Chemical versus nuclear reaction in charcoal
Charcoal, primarily composed of carbon, can yield potassium and sodium compounds when heated due to the presence of these elements in the original plant material. Charcoal is the result of partially burned plant matter, which retains minerals like sodium, potassium, and magnesium. The discussion clarifies that no nuclear reactions are involved in this process. Additionally, the smell of ammonia noted during the decomposition of charcoal may arise from the type of charcoal used; cooking charcoal typically does not emit this odor, while activated charcoal, especially when previously used for filtration, can produce such smells. The conversation also touches on the potential for separating sodium and potassium oxides from the charcoal.
JGM_14
From my experience one cannot under go a nuclear reaction of a material by heat alone, so why does charcoal, which all i have heard is carbon, yeild potassium and sodium compounds when heated? :mad:
Chemistry news on Phys.org
Charcoal is the partially burned or charred remains of plant material. Plants contain sodium and potassium and so does the charcoal and so does the ash. You will probably find magnesium oxide in there as well.
No nuclear reaction here.
I have another related question. how could i separate the sodium and potassium oxides? I have many times noticed the smell of ammonia when decomposing charcoal what is this from?
It depends what the charcoal was used for. Cooking charcoal should not smell like that. Activated charcoal can smell like that, especially if it has been used to filter an aquarium.
the charcoal was from charring plant remains then furthur decomposing them with a strong heat
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
