How Fast Do Spaceships Appear to Each Other at 0.99c Relative Speed?
When two spaceships are moving apart at a speed of 0.99c, the speed of one spaceship as viewed by the other is calculated to be 0.99995c. The relative velocity equation is applied to determine this, using the formula w = |ux - vx| / (1 - ux vx/c^2). There was some confusion regarding the interpretation of the observer's measurements, with initial assumptions about the relative speed being 0.99c. The correct understanding involves recognizing the need for algebraic manipulation to derive the relative speed. The discussion highlights the complexities of relativistic speeds and the importance of precise calculations in such scenarios.
MathematicalPhysicist
An observer sees two spaceships flying apart with speed 0.99c, what is the speed of one spaceship as viewed by the other? the answer is: 0.99995c.
well we have the equation of relative velocity:
\frac{v_1+v_2}{1+\frac{v_1v_2}{c^2}}=0.99c
now i think from the question that i need to find v1+v2 here, cause compared to spaceship 1, spaceship two is moving with speed -(v1+v2) and spaceship 1 compared to two is moving with speed v1+v2.
but how to find it, perhaps i need some algebraic manipulation which i don't see how do, or my above equations are flawed?
If I understand the situation correctly, you're seeing two spaceships moving exactly away from you with 0,99 c in opposite directions. Now you have to use the last equation on the following page: http://math.ucr.edu/home/baez/physics/Relativity/SR/velocity.html with ux=0.99c and vx=-.99c o yield for the relative velocity (as viewed by either of the two spaceships:
w = \frac{|ux - vx| }{ 1 - ux vx/c^2}=\frac{2*0.99}{1-0.99^2}=0.99995
it should be 1+0.99^2 in the denominator.
thanks, i didn't undersatnd the situation, i thought that the observer measures the relative speed between them, and that speed is 0.99c.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
