What is the Most Efficient Propeller Design for a Peddel-Powered Water Craft?
The discussion focuses on designing an efficient propeller for a pedal-powered watercraft intended for a racing competition. Key considerations include estimating maximum speed based on the boat's length and the power output of the pedallers, which may require a gear system to optimize propeller RPM. Suggestions include exploring paddle wheels as an alternative to propellers for easier construction and efficiency. The concept of using supercavitation to reduce water contact is also mentioned as a potential innovative approach. Participants are encouraged to share additional ideas and updates on their progress.
nickindustrial
hey guys,
urgently need your help, I am an industrial design student and at present we have a project that involves designing and constructing a peddel powered water craft. there will be a race upon completion of the craft therefore it needs to be reasonably fast.
If you have any recommendations or suggestions please feel free to respond. The ideal feed back i would like to receive is regarding the most appropriate propellar to use, including draft and angles etc, and whether there is a more efficent solution out, as this craft will be manually operated in a similar manner to a bicycle.
appreciate it guys
cheers
No magic formulas here, but some things to think about:
You might want to start by estimating the max speed your boat is likely to have (which depends mainly on its length). Google for "Froude number".
Then consider how much power your pedallers can generate using something that works like a bicycle for a sustained period of time (Google for power output of athletes for example).
Choose a sensible pedalling speed (and possibly a gear system to convert that to propellor RPM).
Then design a prop that works your chosen input flow velocity and does the right amount of work.
Then have fun working out what went wrong with the design calculations when you test it (that's where the REAL engineering starts!)
Of course if it's a very short race you may be more concerned about acceleration from a standing start than about top speed.
You might want to consider paddle wheels rather than propellors. They could be easier to design (conservation of momentum!) and construct.
Check out Nature volume 424, there's an article (which is also on the cover page) concerning delta shaped paddles.
I would also recommend that you spend some time to look at the items that are readily available. It would be a big plus (and usually a lot easier on you) to be able to use items already manufactured and easily obtainable. You should also be able to get a lot of engineering data about those products if you ask the right people.
If you're involved in the competition I've seen on TV before, these are not surface vessels you're talking about. I've always hoped someone would try applying the principles of supercavitation to one of these races. Not that a human-powered craft could truly supercavitate, but if the driver's exhaled air could be trapped in long bubbles that cover much of the side of the craft, contact with the water could be greatly reduced.
Thanks a lot for the help guys, at present we are looking into the concept of flippers and possibly try and branch off into a less conventional approach, just to see what happens. gratefull for all the recomendations they help alot. its just a minor competion that we are in, just in new zealand.
thanks again guys and feel free to keep ideas coming
will keep u guys posted with our success...or lack of
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
