Why Are My Capacitance Calculations Incorrect?
4 replies · 6K views · last reply
jhess12
http://books.google.com/books?id=1D...are+connected&sig=iwUiJRqZDNHDGOfQfHHvh_9aQ3Y
problem 41 on this link. I got the equivalent capacitance for part a. for the two capacitors with 15 and 3uF- [tex]C_{eq}[/tex]=2.5uF
for capacitor with 6uf- i got the [tex]C_{eq}[/tex]=8.5uF. final answer for a.=[tex]C_{eq}[/tex]=5.96uF. this final anwer is correct according to the answers given to me.
capacitor with 15uF-[tex]Q_{1}[/tex]
capacitor with 3uF-[tex]Q_{2}[/tex]
capacitor with 6uF-[tex]Q_{3}[/tex]
capacitor with 20uF-[tex]Q_{4}[/tex]
for part b. i know that the Q for [tex]Q_{1}[/tex] and [tex]Q_{2}[/tex] are the same because they are in series. the Q i get for them is Q=[V/(1/C1+1/C2)]. If V=15V and
C1=15 and C2=3, then the answer i get is 37.5uC. but the answer in the book says [tex]Q_{1}[/tex] and [tex]Q_{2}[/tex] =26.3uC
for [tex]Q_{3}[/tex]- Q=[tex]C_{3}[/tex]V If [tex]C_{3}[/tex]=6uF and V=15V, then Q should be 90uC. OR if Q=[tex]C_{eq}[/tex]V, then Q=8.5uF(15)=127.5uC. but the book says it should be 63.2uC
for [tex]Q_{4}[/tex]- Q=[V/(1/[tex]C_{eq}[/tex])] If [tex]C_{eq}[/tex]=5.96uF and V=15V, then Q should be 89.5uC- this one i got correct.
I don't understand how i can get certain parts right, but others wrong, unless i am using the wrong equation. Please help, i need to know this for a test.
Start with C4... you did that right... the charge on C4 is just the charge on the Ceq...
What is the voltage across C4? Use V = Q/C...
So what is the voltage across C1 and C2? this is where you made your mistake... it's not 15V...
ok well, i figured that if Q4 is 89.5uC, then Q4=Q, then V3=Q/C=89.5/8.5=10.53V. if
V3C=Q, then 10.5(6uF)=63.2uC=Q3. this appears to be correct, even though i don't understand why. as for Q1 and Q2, i am still confused, i asked my professor to explain it, but he says i should know how to solve this so to figure it out on my own. I keep thinking that it should be Q=[V/(1/C1+1/C2)]. i can see that V=V1+V2, but beyond that...i just don't know
No. what I meant what you know the charge on Q4 is 89.5uC. You know the capacitance of Q4 is 20uF. So the voltage across Q4 is 89.5uC/20uF = 4.475V.
15V - 4.475 = 10.525V
So the voltage across Q3 is 10.525V... so the charge across Q3 is 10.525*6uF = 63.15uC. etc...
i got it earlier from your earlier post, thanks so much
