Solving Related Rates Problem: Understanding Differentiation and the Power Rule
  • Thread starter Thread starter fitz_calc
    Related rates
fitz_calc
Here is the solution to one of my problems:
When inserting dV/dt to differentiate the equation as a function of time, why doesn't the book use the power rule on r^2 and multiply the entire equation by 2? I thought when dr/dt was put into the equation you had to differentiate?
i don't see why there is a need to multiply by 2? if anything, dividing by 4 would clean things up.
and there is no need to apply the power rule on r^2 b/c it was already differentiated.
sorry i can't give you a more detailed answer.
Why would they multiply by 2?
they differentiated it correctly.Unless you are differentiating the wrong statement.
\frac{d}{dt}(\frac{4}{3}\pi r^3)= (3(\frac{4}{3})\pi r^2))\frac{dr}{dt}
which is =4\pi r^2 \frac{dr}{dt}
ahh yeah I was looking at the formula as being 4pi*r^2 instead of cubed, even though it was right in front of me in it's correct form!
Another question given this same example, why do you only differentiate r^2 -- why not 4 and pi as well?
r^3***
and we don't differentiate 4pi bc it's a constant
you could do the product rule on them but you would yield the same results
y=2x
y'=2
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
