How can I accurately measure tension on a wire for my honours project?
To accurately measure tension on a wire for an honours project, a test rig simulating wave motion is used with a 5kg weight as an anchor. Suggestions for measuring tension include calculating the motor's torque or using a strain gauge, although the latter may involve complex circuitry. There is also the possibility of modifying a digital scale to access its analog output for tension measurement. The urgency of finding a solution is emphasized due to the need to balance this task with programming aspects of the project. Exploring these options will help achieve accurate tension measurement efficiently.
jhbroch
Hi, I am currently doing my 4th year honours project and i am having a bit of trouble with one of the aspects of it. i have designed a test rig that simulates the motion of waves and from the test rig i have a wire leading down to an anchor point on the floor (a 5kg weight) , and i need to measure the tension on the wire. From here i plan to use a microcontroller and use fuzzy logic to control a motor which tightens/slackens the wire. I had previously thought i could place the weight on a digital scales with RS 232 output and get a varying weight output from that and then calculate tension but i don't think the output rate of the scales is sufficient. Any other suggestions? all help greatly appreciated!
James
I suppose you could calculate the torque the motor is developing to find the applied tension in the wire.
Welcome to PF jhbroch. The first thing I though of was to use a strain gauge (with electronics) to measure the tension. But the circuits involved might be a bit too much. I did some google searching but most hits were for companies selling measuring instruments.
I'm wondering if you might be able to get inside your scale, find the analog output and then hook it to an A/D to create you output?
hmmm i might look into that actually. and i think the strain gauge idea might be feasible too, either way i need to figure something out but at the same time not have to spend weeks doing it as i still have the programming aspect of the project too...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
