Solving General QM Problem: Finding Commuting Operators
  • Thread starter Thread starter vincebs
    General Qm
The discussion focuses on finding commuting operators for a two-particle quantum mechanical system described by Hamiltonians H_1 and H_2, along with a potential V based on their relative positions. Participants suggest that angular momentum operators L_1 and L_2 commute with H_1 and H_2, respectively, and explore whether the total angular momentum L = L_1 + L_2 is conserved. A method is proposed to prove the conservation of total angular momentum by using an equivalent condition involving rotations of operators. The conversation highlights the connection between classical mechanics and quantum mechanics in understanding these relationships. Overall, the discussion emphasizes the importance of angular momentum in solving the posed problems.
vincebs
Hmm well this question isn't general except in the sense that I have no idea about how to solve it and hence have no idea what physics it involves!
Two particles
particle one obeys H_1 = (p_1)^2/(2m_1) + V1(r_1)
particle two obeys H_2 = (p_2)^2/(2m_2) + V2(r_2)
The system obeys H = H_1 + H_2 + V(|r1 - r2|)
(the latter is the relative distance between the two particles' positions)
r_1 and r_2 are scalars, r1 and r2 are the respective vectors
1.) Find an operator that commutes with H_1 and state its equation of motion
2.) Find an operator that commutes with H_2 and state its equation of motion
3.) Find an operator that commutes with H (and prove that it does)
How do I go about doing this? I can only think of trivial examples, like H_2 commutes with H_1 and vice-versa, and nothing for H.
There is no other information given, so I can't assume this is the helium atom or something.
Two particles
One non-trivial example of operator satisfying condition 1.) is angular momentum
\mathbf{L}_1 = [\mathbf{r}_1 \times \mathbf{p}_1]. This may give you a clue on how to approach questions 2.) and 3.).
Eugene.
Thanks! Ugh! In fact I had considered angular momentum but I thought that its form was particular to the hydrogen atom. But I guess since there is no phi-dependence on the potential it should work fine. So L1 and L2 work for 1.) and 2.), but how about #3? Will the total angular momentum be conserved? If so, how is it defined? Is it just L = L1 + L2? I tried writing out the Hamiltonians in terms of reduced mass but that didn't seem to do anything.
Is there any classical mechanics reasoning I can use? e.g. with Hamilton's equations?
Yes, I think L = L1+L2 should work. You can try to calculate [L,H]=0 explicitly. There is, however, a nicer approach. Try to prove the following equivalent condition
H = \exp(\frac{i}{\hbar} (\mathbf{L} \cdot \vec{\phi})) H \exp(-\frac{i}{\hbar} (\mathbf{L} \cdot \vec{\phi}))
by noticing that for any vector operator \mathbf{a}
\exp(\frac{i}{\hbar} (\mathbf{L} \cdot \vec{\phi})) \mathbf{a} \exp(-\frac{i}{\hbar} (\mathbf{L} \cdot \vec{\phi}))
is the result of rotation of this vector around axis \vec{\phi}.
Eugene.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
