What is a more efficient approach for finding the integral of tanhx?
  • Thread starter Thread starter azatkgz
    Integral
azatkgz
What's wrong with my solution?
\int \sqrt {\tanh x}dx
for u = \tanh x\rightarrow du = \frac {dx}{\cosh^2x}
\int \sqrt {\tanh x}dx = \int\sqrt {u}\cosh^2x dx = \int\frac {\sqrt {u}dx}{1 - u} = \int \frac {du}{2(1 + \sqrt {u})} - \int \frac {du}{2(1 - \sqrt {u})}
for v = (1 + \sqrt {u})\rightarrow dv = \frac {du}{2\sqrt {u}}and for z = (1 - \sqrt {u})\rightarrow dz = - \frac {du}{2\sqrt {u}}
\int\frac {dv(v - 1)}{v} + \int\frac {dz(1 - z)}{z} = v - \ln v + \ln z - z
\int \sqrt {\tanh x}dx = \ln (\frac {1 - \sqrt {\tanh x}}{1 + \sqrt {\tanh x}}) + 2\sqrt {\tanh x}
I=\int \sqrt{tanhx}dx
u=tanhx
dx=cosh^2xdu
I=\int \sqrt{u}cosh^2xdu=\int \frac{\sqrt{u}du}{1-u^2}
Notice, that cosh^2x=\frac{1}{1-tanh^2x}
Then, let t=\sqrt{u} \frac{dt}{du}=\frac{1}{2\sqrt{u}}=\frac{1}{2t}.
I=2\int \frac{t^2dt}{1-t^4}=\int \frac{dt}{1-t^2} + \int \frac{dt}{1+t^2}
So, your problem is: when you substitute dx you write the same dx in integral. But it is wrong! You must write du :)
Also look at cosh^2x=\frac{1}{1-tanh^2x}
it would be faster to make a u^2 substitution
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
