Chemistry Calculating % of Calcium Carbonate in Limestone
  • Thread starter Thread starter Trail_Builder
    Confused Moles
To calculate the percentage of calcium carbonate in limestone, start by determining the moles of hydrochloric acid (HCl) used and the moles of sodium hydroxide (NaOH) required for neutralization. The initial moles of HCl in the solution are calculated to be 0.005, while the moles of NaOH needed for neutralization are 0.002105. This indicates that 0.002895 moles of HCl reacted with the limestone, leading to the conclusion that 0.0014475 moles of calcium carbonate (CaCO3) were present in the original sample. The final calculation will yield the percentage of calcium carbonate in the limestone sample. Understanding the mole ratios in the reactions is crucial for accurate results.
Trail_Builder
I thought I knew moles inside out, but I havnt quite been told how to factor in what happens when you dissolve something in something.
1.500g of a sample of limestone was dissolved in 50cm^3 of a 1.00 mol/dm^3 of hydrochloric acid solution. The resulting solution was made up to 250cm^3 precisely with distilled water. 25.0cm^3 of this solution required 21.05cm^3 of 0.100 mol/dm^3 of sodium hydroxide for neutralisation.
Calculate the % of rock which is calcium carbonate.
mol of HCL:
mol = (vol/1000)*conc
50cm^3 is 1 mol/dm^3, so added with water up to 250cm^3 will be 0.2 mol/dm^3
mol(HCl) = 0.250*0.2
mol(HCl) = 0.05
but then we only take 25cm^3, so...
mol(HCl) = 0.005
mol of NaOH:
mol(NaOH) = (vol/1000)*conc
mol(NaOH) = (21.05/1000)*0.1
mol(NaOH) = 0.002105
Now I get stuff, I am not sure what the effect of dissolving 1.5g of limestone will even have, so I am stuck :S.
Hope you can help.
Thanks
The NaOH is needed to neutralise any HCl that wasn't 'used up' by the limestone - you just have to work backwards.
1, Work out many moles of NaOH
2, How many moles of HCl would this react with
3, How much HCl was made up originally.
4, - subtract (2)
5, how much CaCO3 would this HCl react with?
so for 1) I have 0.002105
for 2) 0.002105 (because 1:1 ratio)
3) 0.005
4) 0.002895
5) 0.0014475 mol of CaC03 right? (because the equation would be CaCO3 + 2HCl goes to CaCl2 + H2O + CO2, so 1:2 ratio)
just checking lol.
thanks for your help :D
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
