What is the Proportionality of Electrostatic Potential at a Distance?
Reshma
(Objective type question)
Consider a square ABCD of side a, with charges +q, -q, +q, -q placed at the vertices, A, B, C, D in a clockwise manner. The electrostatic potential at some point located at distances r(r>>a) is proportional to?
V =\frac{1}{4\pi \epsilon_0}\sum_i \frac{q_i}{R_i}
From the equation for the electrostatic potential is the obvious that V will be proportional to 1/r. I am a little confused by the options given to me...so just want to confirm.
Other options:
a] Constant
b] 1/r^2
c] 1/r^3
Hi reshma,it is the 1/r^3 which is the correct answer.Note that it is a quadrupole...You may wish to refer to Griffiths page 147.
Thanks a billion, neelakash! I knew something was fishy with my answer...I never thought of the quadrapole moment.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
