Dragon software vice recognition failed ram
  • Thread starter Thread starter lordlactose
    Ram Software
Dragon NaturallySpeaking 9 requires a minimum of 512MB of RAM and a 1GHz processor for installation. Users have noted that version 8 successfully installed with only 256MB of RAM, suggesting that older versions may be an alternative. Upgrading RAM is recommended, with 1GB being standard and 2GB being a cost-effective option. Installing RAM is generally straightforward, and users can often do it themselves, though the process may vary depending on whether the computer is a desktop or laptop. There are discussions about potential workarounds for RAM limitations, but these methods, such as "fake RAM," can severely degrade application performance and are not advisable.
lordlactose
failed to install dragon naturally speeking 9. Said system does not have enough ram to run dragon you need minimum of 512 ram. Is there a way aroudn this? If not how should I install ram and what should I pay. Hopw do i get out of this situation.
Computer science news on Phys.org
I seem to remember installing version 8 of dragon naturally speaking with 256MB of RAM. Worked fine. Maybe you can get the older version.
It would be a good idea to upgrade your RAM though. About 1 GB is normal nowadays. With how cheap memory is, why not go for 2GB. See here for typical prices:
http://www.newegg.com/Store/Category.aspx?Category=17&name=Memory
Also version 9 requires a minimum 1GHz processor. Its reported that it won't install on anything less.
http://www.lasplash.com/publish/Har...agon_Naturally_Speaking_9_Software_Review.php
hmm. no tricks aroudn this one. Thanx for helping! I appreciate it
Will I be able to install ram my self? Or will I need to pay someone. If I can do it my self how do I do it?
Its fairly straight forward to install the memory modules yourself. Do you have a desktop or a laptop? Whats the make and model of your computer?
Well don't count tricks out as yet. People have done the "fake RAM" trick on OS X. See:
http://forums.macosxhints.com/showthread.php?t=53854
If you have a microsoft OS, then you'll have to google to see how RAM faking is done. Assuming that you can do it. It would be a very bad idea, as application performance will be severely degraded. Theres a reason why the installer is checking for minimum RAM requirements.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
