What is the constant force exerted on a ball by a wall during a collision?
A 5.00 kg ball collides with a wall, initially moving at 6.0 m/s to the left and bouncing off at 5.0 m/s to the right, resulting in a change in momentum. The initial momentum is calculated as -30 kg·m/s, while the final momentum is +25 kg·m/s, leading to a total change in momentum of 55 kg·m/s. Using the formula for force, F = change in momentum / time, and substituting the values gives a force of 183.3 N to the right. This calculation aligns with Newton's second law, confirming the result. The analysis demonstrates the application of momentum principles in collision scenarios.
mortho
A 5.00 kg ball strikes a wall with a velocity of 6.0 m/s to the left. The ball bounces off with a velocity of 5.0 m/s to the right. If the ball is in contact with the wall for 0.30 s, what is the constant force exerted on the ball by the wall?
f=p/t
Ok so i found p which i did mv or (5)(11) then plugged it to p/t and did 55/0.30 and got 183.3 N to the right...is that correct?
Thanks!
Initial momentum is 5*-6=-30 kgms^-1
Final momentum is 5*+5=+25kgms^-1
what is the change in momentum? how does Newton's 2nd law apply?
oh...so 5 **Net force on an object is equal to its rate change of momentum.
but that's such a small number is that possible??
YesThe change in momentum=Final-Initial=25-(-30)=55kgms^-1
and by Newton's 2nd law:F=55/0.3
so you are correct.
