Euler expansion of double exponential?
Clifford
Simple question,
I have used the euler expansion to estimate a variable that grows as a single exponential.
adapt = Amax * exp(-tau*X);
In excerpted form:
for (i=1;i<npts; i++)
adapt = adapt[i-1] + (Amax -adapt[i-1]) * dt / tau;
where dt is the step size and tau is the 'time constant.'
Now, however, I think that the data would be better fit with a double exponential.
adapt = a(1) * exp(-tau1*X) + a(3) * exp(-tau2*X);
I am unsure how to expand this analogously to the single exponential.
thanks!
Clifford
Assuming that a(1) and a(3) are some incremental values, you can define your system as an autonomous system as, \dot{x} = Ax where A is a 3 \times 3 matrix and x \in \mathbb{R}^3, then expand the matrix exponential. And take the first state.
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
