Why Did the Water's Temperature Increase Without Adding Heat?
The discussion centers on a scenario where the temperature of a cup of water increases from 20 to 25 degrees Celsius without any heat being added. The key conclusion is that no external heat was introduced, as heat naturally flows from warmer to cooler objects. The temperature rise could be attributed to factors like room temperature changes or the melting of ice if present. The question is framed as a trick to provoke critical thinking about heat transfer principles. Ultimately, the increase in temperature does not imply added heat but rather a change in environmental conditions.
Benzoate
A cup containing 200 grams of H20 is siting on your dining room table . After carefully measuring its temperature to be 20 degree celsuis , y ou leave the room. Returning ten minutes later, you meaure its temperature again and find that it is now 25 degree celsuis. What can you conclude about the amount of heat added to water?(hint: this is a trick question)
My response to this question was that there is no heat added or heat is equal to zero since heat is a spontaneous process where heat flows from a hot object to a cold object. Even though there is a temperature difference involved in this process, The temperature increases rather than decreases.
Ah, this is interesting...
I making a wild guess here.
Is it because ice (also H2O) in cup has melted?
If not, the question setter will say "200 g of water" instead of "200 g of H2O"
Hehe...
