Influence of temperature on the coefficient of restitution
dietwater
coursework - I will be varying the temperatures of steel ball bearings as they drop onto a metal plate, with the bounce heights, i can work out the coefficient of restitution. however, i need help on the theory behind how temperature will actually effect the coefficient. e.g: how temperature effects the elasticity of the materials as the impact will depend on this, or how temperature is related to the coefficient of restitution.
coefficient of restitution = squareroot (bounce height/original height)
My theory on this would be that the temperature will increase the coefficient of restitution as the heat energy will cause the lattice to vibrate - thus making the solid less 'stiff' and increase in elasticity which will increase bounce height -> increase in coefficient of restitution however, some articles say that increase temperature should decrese the coefficient of restitution?
anyhelp on the theory behind this would be greatly apprreciated, any more infomation needed.. please ask :)
Thanks in advance!
Thanks in advance!
Hi there,
Can you please post the results of your investigations?
Many thanks!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
