Why Does Superposition Give Different Results in PSPICE?
The discussion centers on the application of superposition and Thevenin's theorem to find the voltage across a load resistor (Vload). Initial calculations yielded a combined voltage of 6.12 V using superposition, but a PSPICE simulation showed a different result of 4.33 V. The discrepancy arises from incorrectly applying superposition by neglecting to replace other voltage sources with their internal resistances. Correcting this involves using the parallel resistance formula for the voltage sources. The final conclusion emphasizes the importance of accurately modeling the circuit components in simulations.
jesuslovesu
Never mind, did superposition incorrectly.
http://img258.imageshack.us/img258/9206/jesus2gn2.th.png
Find Vload using superposition and thevenin's equivalent
Well for network on the left of Rload, I found Vth = 5 V and Rth = 15.1 kohms
For the network on the right of Rload, I found Vth = 7.5 V and Rth = 8150 ohms.
So using superposition I would do:
1) 5 V * 10k / (10k+15.1k) = 1.99 V on Rload
2) 7.5 V * 10k / (10k + 8150) = 4.13 V
Adding those I get 6.12 V.
However, when I simulate this in PSPICE I get 4.33 V.
I also checked each side and I get 1.99 V on the left (when I disconnect the right) and I get 4.13 V on the right (when I disconnect the left).
What am I doing wrong, I can't even remotely see where that 4.33 V comes from.
When you calculate the voltage on the load due to one voltage source, you can't just remove the others, but need to replace them with their internal resistance.
for 1) you'd get 5 v * (10K // 8150) / ((10K // 8150) + 15.1k)
(A // B) is the value of the resistance of A parallel with B, or AB/(A+B)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
