What Is the Equation of a Line Inclined at 130 Degrees Through (0,2)?
  • Thread starter Thread starter jayar182
To find the equation of a line inclined at 130 degrees through the point (0,2), the slope must be calculated using the tangent of the angle, which is the tangent of 130 degrees. The standard form of the line's equation is y = mx + b, where m represents the slope and b is the y-intercept, which is 2 in this case. The slope derived from the angle will be negative, reflecting the line's downward inclination. Understanding the relationship between the slope and the angle is crucial for formulating the equation correctly. The discussion emphasizes the need to connect the slope with the line's equation format.
jayar182
find the equation of the line with the inclination 130 degrees going through point (0,2)
baffled at how to start...
thanks!
What do you know about the equation of a line?
Maybe drawing it 1st will give you an idea of what the equation should be.
A line of inlcination 180\cdot going through (0,2) would have the equation: y = 2
What is the slope of the line?
for the past two days, I couldn't enter this site...
thanks, for the equation, this is all the information given...I assume it will be in a "y=mx+b" format, but I am not sure. also the slope has to be a 130 degree angle with the horizontal axis (I believe the x axis)...
if it helps, the class is math analyst, which is the one before calculus...
thanks!
No, the "slope" of a line, in this sense, is NOT the angle it makes with the x-axis, it is the tangent of that angle. Now, how is that "slope" connected with y= mx+ b?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
