Understanding of electrochemistry
  • Thread starter Thread starter jaredmt
    Electrochemistry
The discussion revolves around the phenomenon of batteries heating up when short-circuited. A user recalls an experience where a battery became hot when in contact with metal objects like keys and change. They experimented with different metals, including a penny and a paperclip, to replicate the effect. The key point is that creating a conductive path between the positive and negative terminals of a battery leads to a short circuit, causing rapid heating. If the battery does not heat up, it may indicate a broken connection or a dead battery. The user successfully created a short circuit with a paperclip, raising the question of whether this could ignite a fire. They also discovered that removing the tape from the battery's negative end exposes the anode and cathode, facilitating the short circuit.
jaredmt
just wondering. i remember once i had a battery, some change, and my keys in my pocket and eventually i reallized the battery got really really hot. just for the heck of it i tried to get that to happen again and it didnt work. can someone explain why this happenned before?
i tried putting a penny on the - end and connected it to the + end with my keys. and i tried it the other way around too but didnt work. i guess my keys are made of zinc and copper.
edit: or would this just take a long time? cus i don't feel like sitting there for 2 hours. i was just trying to further my understanding of electrochemistry
Chemistry news on Phys.org
Short circuit is a key word here.
If you make a connected path of metal between the + and - terminals, that's a short circuit and the battery will heat up noticeably. Probably within a half a minute. If that does not happen, either the connection was broken somewhere or possibly the battery is already dead.
ok i tried it again with a paperclip and it worked in like a few seconds. is it possible to create a fire with a battery and paperclip?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
