Composition of homomorphisms is a homomorphism
futurebird
Prove that if f: G \to H and g: H \to K are homomorphisms, then so is g \circ f: G \to K.
2. The attempt at a solution
Since f is a homomorphism (G, * ) and (H, \circ) are groups and f(a*b)= f(a) \circ f(b), \forall a,b \in G. Likewise, (K, +) is a group and g(f(a) \circ f(b)) = g(f(a)) + g(f(b)), \forall f(a), f(b) \in H with a, b \in G. Hence, g \circ f = g(f(x)) \forall x\in G. g \circ f is a homomorphism.Is this anything like correct?
*bump*
Someone will correct me on this, but I'm pretty sure I'm not incorrect.
First of all, you shouldn't say the homomorphism implies G and H are groups. The problem should start out with
Let <G,*>, <H,o>, and <K,+> be groups and let f: G->H be a homomorphism and g: H->K be a homomorphism prove that (g o f): G->K is a homomorphism.
If I was in trouble doing this problem, I'd first state what I need to show:
NTS: (g o f) (x*y) = (g o f)(x) + (g o f)(y) for all x,y in G.
This is the homomorphism property.
So if you pick any 2 random elements in G and "combine" them, then pop them into (g o f) you should get the same result as if you first popped each one into (g o f) then "combined" them. This is english for homomorphism.
I guess the only thing left is take 2 elements in G and show that what we said in two different ways is true.. ie:
Proof:
Let x, y \element of G, then { ... } done!
I think what you've done above is good.. just need to structure it better =)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
