Maximizing Toboggan Speed: Calculating Slope and Adjusting for Weight and Dips
  • Thread starter Thread starter zoltar
    Speed
To achieve a speed of 40 mph on a toboggan, a height change of approximately 209 meters is required, calculated using gravitational potential energy principles. The weight of the toboggan does not affect acceleration due to gravity, so the slope needed remains consistent regardless of weight. Adjustments for dips in the hill are complex, as they depend on factors like friction and air resistance, which vary by toboggan design and snow conditions. A simple formula does not exist for these variables, suggesting that empirical testing may be the best approach. Understanding the relationship between height, slope, and speed is crucial for optimizing toboggan performance.
zoltar
i need help, i need to calculate the slope of a hill to reach 40mph on a toboggan? how do i do this with a fluctuating toboggan weight...meaning what is the slope i require for different weights? also how would i adjust for dips in the hill?
can anyone help? this is not might area and would appreciate something simple that i could use.
thanks!
Welcome to PF!
Hi zoltar ! Welcome to PF! :smile:
Acceleration is what matters, and as Galileo proved (on a slope, by the way), all weights have the same acceleration under gravity.
So the weight doesn't matter. :smile:
Not following you … what sort of dips? :confused:
It's not so simple.
It depends on the friction of the toboggan on the snow - which depends on the design of the toboggan, and the quality and temperature of the snow.
And then it also depends on the air resistance of the toboggan and its rider(s).
So there isn't a simple formula that will give the right answer. You're probably better conducting an empirical experiment (trying it out for real, and seeing what results you get).
It is relatively simple if you assume no air resistance/friction etc. But it will depend on how much space you have and how quickly you want to reach your target speed.
\frac{1}{2}m (\Delta v)^{2} = mg \Delta h (kinetic energy gained = gravitational potential energy lost)
\Delta h = \frac{v^{2}}{2g}
= \frac{(40*1.6)^{2}}{2*9.8} = 209m
So you will need a height change of 209m to achieve 40mph. Now you can calculate, using right-angled-trigonometry and knowledge of the space available, the angles you'd need to achieve this. Note this is just an approximation of course.
One should be careful with units here. The numerator would have units if (km/hr)2 and the denominator units of m/s2, so one must apply conversion factors 3600 s/hr and 1000 m/km. In doing so, the above expression becomes,
= \frac{(40*1.6)^{2}}{2*9.8*3.6^2} = 209 / (3.6)^2 m = 16.1 m
Also, the change in kinetic energy is proportional to \Delta(v^2), not (\Delta{v})^2.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
