Trigonometry question find range
The discussion centers on finding the range of the expressions (sinx)^4 + (cosx)^4 and (sinx)^6 + (cosx)^6. Participants suggest using algebraic transformations and trigonometric identities to simplify the problem. The first expression can be rewritten as 1 - (1/2)sin^2(2x), which helps in determining its range. The focus shifts to understanding the outputs of these functions rather than their domains. Ultimately, the key is to analyze the final transformed expressions to find their respective ranges.
fantasy
guys , following is the problem
(sinx)^4 + (cosx)^4
and
(sinx)^6 + (cosx)^6
they are asking for the range for each of them
i really have know clue how to solve this...any sugeestion please?...thanks for reading this!
Both of them can be solved in the same way I think. Here is a hint on how to transform the first one.
a^4 + b^4 = (a^2 + b^2)^2 - 2a^2b^2
so the other one will be
(a+b)^6 =(a^2 +b^2)^3- 3a^2b - 3ab^2
rite?..
i tried to solve and factorize the first one but can`t
it becomes 2(sin^2(x))^2 - sin^2(x) + 1 ??
Use the property sin(2x) = 2sin(x)cos(x)
thanks praharmita... but there is not sin 2x ?
it`s ((sinx)^2)^2...
you don't have to write everything in terms of sin(x) as you did. Use the original form as given by snipez90, where there is a 2a^2b^2 term, and then use the identity of sin(2x)
ooo i see...thanks again...
is the ans 90<x<270 for the first one ?
I assume you mean degrees, in which case you are thinking about the domain but we want to focus on the range (the outputs of our function).
We have
sin^4(x) + cos^4(x) = (sin^2(x) + cos^2(x))^2 - 2sin^2(x)cos^2(x) = 1 - [2sin(x)cos(x)]sin(x)cos(x) = 1 - sin(2x)(\frac{1}{2}sin(2x)) = 1 - \frac{1}{2}sin^2(2x)
Now using what you know about the range of sin and the nature of squared quantities, determine the range of the final expression.
