Function Example Ideas: Tips, Suggestions, and Help
  • Thread starter Thread starter iscreamath
    Images Inverse
iscreamath
http://answerboard.cramster.com/other-topic-5-311900-0.aspx"
I need help getting some ideas for an example of a function.
Any help, ideas, suggestions, and/or tips are greatly appreciated.
Thanks for looking at this question!
You are sort of muddling up domain and range. If f:A->B then H must be a subset of the range B, right? And if b is an element of B such that there is no a such that f(a)=b you are defining f^(-1)({b})={} (the empty set). Also correct? Then just consider any function that isn't onto. Any one. You pick.
thank you
thanks for the help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
