Calculating Al Foil Thickness in mm
  • Thread starter Thread starter mightyhealthy
    Thickness
To calculate the thickness of a sheet of aluminum foil with an area of 1.000 ft² and a mass of 3.636 g, the density of aluminum (2.699 g/cm³) is used in the formula d = m/v. The volume (v) can be derived from the mass divided by the density. The initial attempt at a solution was incorrect, indicating a misunderstanding of the units and calculations involved. Clarification on the variables used in the density equation was sought, emphasizing the need for accurate unit conversion to find the thickness in millimeters. The discussion highlights the importance of correctly applying formulas and understanding unit conversions in physics problems.
mightyhealthy
A Sheet of aluminum(Al) foil has a total area of 1.000ft^2 and a mass of 3.636g.
What is the thickness of the foil in millimeters (density of Al=2.699g/cm^3)?
d=m/v
1.347=totally wrong... help please
1.347 is probably the right answer in some system of units :-p
Also, what is the d in your "relevant equations"? Is it the d for density? Or is it the d that is sometimes used for small distances (such as, say, thickness?) And what is v? How do you calculate it from the given data?
Your "attempt" is not so much an attempt from which we can clearly locate some error, as some numerical guess, without units or any other relevant information.
thank you
You're welcome.
I take it this means you solved it?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
