Uniform circular acceleration and direction
The discussion revolves around calculating the speed, magnitude of acceleration, direction of acceleration, and the angle between a bird's velocity vector and the horizontal while it rises on thermals. The bird completes a circular motion with a radius of 8 meters every 5 seconds and ascends vertically at 3.0 m/s. The speed relative to the ground is determined to be 10.5 m/s, and the magnitude of acceleration is calculated as 12.6 m/s². The direction of the bird's acceleration is found to be 13.3 degrees above the horizontal, but there is confusion regarding how to interpret the direction of centripetal acceleration. Clarifications are sought on how to approach the calculations for the angle and the nature of the bird's acceleration.
anubis01
Birds of prey rise up and down on thermals. A bird completes circle of radius 8m every 5s and rises vertically at a rate of 3.0 m/s. Assume uniform acceleration. Find
a)speed of bird relative to ground
b)magnitude of acceleration
c)direction of birds acceleration
d)angle between birds velocity vector and horizontal.
ar=V^2/R
I have found the answer to a be 10.5 m/s, the answer to b is 12.6 m/s^2
c)at/ar=tan^-1(3/12.6)=13.3 degrees
d) I'm not sure how to proceed for this equation.
Any help is greatly appreciated and thank you for your time.
For part c the bird is in uniform circular motion. The bird is rising at a rate of 3m/s is not an acceleration.
For part d you have the vertical component of velocity and the component tangent to the circular motion. Find the resultant.
Thanl you very much sir for the help and I finally got d :). HOwever I'm still a little bit confused about c. Centripetal acceleration has the same magnitude but varying direction so how am I supposed to find the direction of the birds acceleration above the horizontal.
C says nothing about direction above the horizontal, it merely asks for direction as you have typed it.
I see, thanks again.
