Amplitude of sound wave in by 50%
The discussion centers on calculating the increase in decibel level resulting from a 50% increase in the amplitude of a sound wave. The initial calculation shows that increasing the intensity from 2.0 x 10^-7 to 3.0 x 10^-7 leads to an increase of approximately 1.8 dB. Another participant suggests a more straightforward method using the formula 10 log10(1.5), which yields an increase of about 1.76 dB. Both methods effectively demonstrate that a 50% increase in amplitude corresponds to a slight increase in decibel level. The calculations confirm the relationship between amplitude and sound intensity in decibels.
hemetite
Any kind soul to help me with this questions...i am stuck
qn. The amplitude of vibration of a certain sound wave is increase by 50%. What is the corresponding increase in the decibel level of the sound?
My attempt..
beta= 10 log ( I/Io)
lets just take I = 2.0 x 10^-7
let just take Io= 1.00 x 10^-12
then 10 log( 2.0 x 10^-7/1.00 x 10^-12) = 10 log (2.0 x 10^5) = 53db
if we increse I by 50 % = (2.0 x 10^-7) x 1.5
= 3.0 x 10^-7
then
10 log( 3.0 x 10^-7/1.00 x 10^-12) = 10 log (3.0 x 10^5) = 54.8 db
so the change of decibel = 54.8db - 53db = 1.8db
correct attemp this question this way??
My attempt..
= 3.0 x 10^-7
then
Since the increase is by a factor of 50% you can also express the increase
as simply 10log10(1.5) = 10*(0.176) = 1.76 db
