What Do Others Think About Determinism?
Determinism suggests that all events, including human actions, are predetermined by prior causes, raising questions about free will and personal responsibility. The discussion highlights the tension between the belief in a predetermined life path and the influence of biological factors on decision-making. Participants explore whether the existence of unchanging chemical processes in the body implies that choices are predetermined. The conversation indicates a need for a deeper understanding of how determinism interacts with concepts of accountability. Overall, the debate centers on the implications of determinism for human agency and moral responsibility.
Steph191290
I am writing an essay on determinism, i was just wondering what peoples opinions on it are, my argument is going to be that it is possible, but i would like to include other peoples opinions and reasons.
Thanks Steph.
as opposed to what?
is this about freewill?
yeah, basically do you believe that our path in life is already chosen.
if the world isn't deterministic then how could anyone ever be held responsible for anything?
But at the same time something must help us make our desicsions, possibly the chemicals in our body and if that's the case, our chemicals don't change therefore our choices are already made.
